fall_down_stand_up
It will run hotter....Im running a NGK B6HS right now....oppinions????
John-John
John-John
Its the factory carb(new in the box) I just put on off one of my new Raw kits....Its has a much larger throat (slide)than the Thatsdax carbs I was running....You runnin the stock carb ona 66cc? If so - is it the old style or the new one with the second fuel petcock on it?
...The wrong plug will either foul out in really cold weather, or cause detonation in extemely hot weather...
