Old 11-15-2009, 11:29 AM
fall_down_stand_up's Avatar
fall_down_stand_up fall_down_stand_up is offline
Default Re: CARBS...I give up
Originally Posted by Kevron99 View Post
No Sir...the clutch cable is not running or binding with the throttle. I do not know the question about twisting the throttle. This issue is about idle..what I know you should not twist the throttle if you want to idle. It should be in the un twisted position...correct?
See the pics below..Thanks
Your fuel filter should be above the carb....Under RPM's it might be sucking the fuel in but at idle you might not be getting enough draw....Shorten your fuel line so it will get the filter about the carb.....Thats just my 2 cents
IF I CANT FIX IT,IT ISN'T BROKEN!....ummmmmmm so I thought....
