Old 11-03-2009, 03:23 PM
Dan's Avatar
Dan Dan is offline
Default Re: The *BEST* Solution for "THE" tensioner/pulley
Originally Posted by sportscarpat View Post
New around here and my first attempt at a motor bike and my solution to the idler sprocket. I will try to post a picture. Here goes. Well, the attachment worked. I used a #41 Diamond brand chain, an 18 tooth idler sprocket with bearing insert, tig welded a small laser cut tab to the bottom of my frame. The weld on tab is slotted to corectly adjust chain tension. Works great and have had absolutely zero problems.
Very cool! Really like the looks and function. Purty work Sport.
worst apocalypse ever
