Old 10-27-2009, 05:52 AM
bandito bandito is offline
Default Re: new member - first install - questions? of course
Bairdco when these kits are new do the clutch plates have a tendency to grab until their worn a little? Could the idle just be too low on his motor and thats the reason its dying when stopped? None of this will matter if the clutch cable isnt adjusted properly. Ive seen that actuator shaft in pics and its a half round shaft, if the clutch cable is tight when released isnt that all that is nesessary in the cable? Doesnt seem theres too must adjustment you can do to a half round shaft unless under tension from the cable at rest you want it rotated partially to increase the distance between the pads and the clutch plate when the clutch handle is pulled in.
