Old 10-22-2009, 05:32 AM
xlite xlite is offline
Default Re: Cranbrook, Chain shake/flap/slap
Originally Posted by BarelyAWake View Post
I'm not quite sure what you mean, if you mean move the axle rearward thus adjusting tension - I don't think that's an option ;
If you mean space the hub/sprocket to driver's right to allow more clearance for chainstay/chain - I don't really want to do that as it's in line with the engine's 10t so perfectly now...
or... am I misunderstanding?
On most of the models I've done the axle cannot be moved all the way back because they put a small "slug" inside the right dropout to hold the derailleur from rotating. You usually can't see it w/o loosening the derailleur. Most bikes can still adjust chain tension enough (1 link) but a few needed to have that "slug" replaced by a bolt outside the dropout or else need a half link. One or the other. Anything to get rid of that dam tensioner.
I can't take pics now but will do so when I can.
