Old 10-22-2009, 01:07 AM
karma1968's Avatar
karma1968 karma1968 is offline
Default diy Lighting System
looking over these motors there's not a lot of room to make a gen. but after a few failures
i may have something that will work. problem with using the white wire it shares the ground with the magnito. to much of a load and it effects the cdi. there are products on the market but im cheap so
here we go...
just to be sure i had the proper winds in the coal i unwound a magnito. took about two hours without damaging the wire.
the iron core is from a microwave fan. will be cut to fit coal slot with epoxy.
ill go into more detail if it works... as you can see in the pics it likely will after i get another magnito lol
