Old 10-16-2009, 09:03 AM
fall_down_stand_up's Avatar
fall_down_stand_up fall_down_stand_up is offline
Default Re: Engine running at half throttle,whats up????
Thanks for the responses....I took the slide out of the carb when I first had the problem and when I twist the throttle it goes all the way to the top....I Will take an extra throttle cable I have laying around and try it and see it it changes....If that doesnt work I will change the carb to a third one and see it that helps....
IF I CANT FIX IT,IT ISN'T BROKEN!....ummmmmmm so I thought....
