Old 10-15-2009, 03:42 PM
fall_down_stand_up's Avatar
fall_down_stand_up fall_down_stand_up is offline
Default Re: Engine running at half throttle,whats up????
Originally Posted by BarelyAWake View Post
erm... the dreaded leaks perhaps? Carb/manifold would be likely...
That's what I would start lookin' for anyway Do you have idle problems?
It idles perfect and runs smoothly,the spark plug is running rich and I cant choke it at all or it will die so I dought it is a air leak....The engine has 80 miles on it and im running 50:1 synthetic blend 2 stroke oil....I changed the carb out with a new one I had laying around and still the same problem....It is not 4 stroking,the idle does not go up and down it just runs smooth but wont rev up all the way....
IF I CANT FIX IT,IT ISN'T BROKEN!....ummmmmmm so I thought....
