Old 05-25-2008, 10:34 PM
Dave31's Avatar
Dave31 Dave31 is offline
Default Re: Flatless Tires or tubes ????
I have used old tire as liner's. What I do is cut the sidewalls out and then put them in the tire and use them as a liner between the tire and tube. This will add wieght and it takes a few times of adding air and letting it out to be sure you don't pinch the tube anywhere, but I have never had a flat using that system. I've also just used old tubes as liner's, just cut the steem out.
