Old 10-10-2009, 09:06 PM
Hazmatt's Avatar
Hazmatt Hazmatt is offline
Default Re: Stainless, Problems?
Okay, So,
What I did was drill and tap the top of the tank for 3/4" NPT. and 1/2" npt. For the filler pipe I am using a 3/4" rigid conduit nipple threaded into a coupling. I will just thread a conduit cap into this to use as the gas cap. On the other end I'm using a 90 degree brass Swedgelock fitting. It's got 1/2" npt threads and 1/4" pipe compression fitting. This will be the vent. I'm using the same setup on the bottom for the gas line. Because the metal is a little thin, (not much to thread into) I soldered the fittings to the top of the tank as well.
If you're not part of the solution,
You're part of the precipitate.
