Old 10-10-2009, 01:30 PM
Junster's Avatar
Junster Junster is offline
Default Re: Clutch grabs after engine warms up.
Good idea to remove the return spring. The only purpose it serves is to make the clutch pull hard. To make the clutch pull even easier. Use a dremel and round off the rear edge of the flat that pushes the pin that disingages the clutch. Just round off the sharp edge a little so it slides easier on the pin. Makes a noticable difference and makes the clutch "feel" alot smoother.
Put something FUN between your legs..
