Old 10-09-2009, 07:01 PM
wes's Avatar
wes wes is offline
Default Re: chain maintenance
It sounds like your rear sproket is not centered around the hub, take the rim off the bike and put it in another bike or something that you can spin the rim in to look at the sproket from a side view, you sproket should not move up and down as the rim spins, if you take a moment and think about this you will relize that if the sproket is moving upand down it is also moving side to side causing the chain to tighten and then loosen. And make sure the master link clip is facing closed end forward while it rotates around the front sproket, Good Luck!!!
