Old 01-21-2008, 11:56 AM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: chain tension help
here the tensioner mount is a little different and while building the bike I built up the area where the tensioner mounts by welding on donated frame material form a donor bike. You might be able to use a propane torch and solder and do the same thing if you don't have a welder. The solder to use would be the stuff plumbers use to solder together metal ducting.
