Old 09-18-2009, 08:19 PM
bandito bandito is offline
Default Re: Mounting Engine without a ton of tools?
If you have alot to grind that drill with a grinding stone will work alot faster than a dremel. Hack saw if needed is cheap, just use your imagination and tool king can be your friend. The only special tool Ive needed so far was a 15mm super thin wrench for an axle locking nut. Tools youll need dont need to be snapon type tools with a lifetime of debt to pay for. Heck if you bought a 100pc tool set youd have 95% of what ever youd need and those kits can be had for $50 or cheaper/higher depending on the quality you want. Ive seen alot of speacialized tools for cassetes and cranksets but I havnt got into a bike that far yet maybe some day theyll be needed.......
