Old 09-16-2009, 09:01 PM
tdaddydolla tdaddydolla is offline
Default Re: New Guy in MidWest
Thank you !!!!!! i found a 415 kmc heavy duty bmx chain. it was a perfect size!
my only problem now is the clutch!!! i tapped with hammer,,, then pulled out rod to check bearing ball... so well greased couldnt see it or pull it with my magnet..
i tried to fit another ball to check but rod stuck out too far then, so i must have original ball still.....????? so is the only thing left is to check outherside for the spring or something? is there more to do while im on the more easy access side?
