Old 09-11-2009, 09:23 AM
drhofferber drhofferber is offline
Default Re: Did my china girl blow up??
Originally Posted by fall_down_stand_up View Post
When I push the clutch lever in the sprocket turns smoothly,but when I release it the piston wont move....Im convinced it has to do with the aluminum head gasket being off center and getting chewed up and peices down in the cyclinder,unless you know of something that could be causing the clutch to lock it up?....
aka granbury_man
sounds like the needle bearings went...i had same problem....broke engine in with the best syn oil...wont mension name...not one engine..2 engines....both went down at 200 i use basic 2 stroke oil...good luck...Dennis
