Old 09-01-2009, 03:03 AM
Junster's Avatar
Junster Junster is offline
Default Re: Will this spark plug wire work?
Usually the wire says on the outside if it's solid core. Solid core is copper stranded wire. I agree with Tom you need all the spark you can get. If you cut some insulation off the stock wire it has only 4 small conductors. I used the Accel wire for 2 reasons, I had one laying around, I thought the yellow wire looked cool. Also remember that a 2 stroke will always run better on a colder range plug. I use a NGK b7hs. Of course opinions may vary..
PS. If you really want to pony up you can order a NGK solid core racing single wire. They have a resistor netting molded into the plug boot and cost about $16, for one.
Put something FUN between your legs..
