Old 08-31-2009, 04:53 PM
fall_down_stand_up's Avatar
fall_down_stand_up fall_down_stand_up is offline
Default Re: Spray carb cleaner by carb to intake and engine die's.
Originally Posted by Kevlarr View Post
Are you sure you're not getting any of the spray into the carb? It doesn't take much to stall one of these little motors.
That was my thoughts exactally....Im wondering if the carb is sucking the over spray into the air cleaner....I will keep an eye on the plug to see if it starts to look like it is running lean....
Thanks for the reply
IF I CANT FIX IT,IT ISN'T BROKEN!....ummmmmmm so I thought....
