Old 08-31-2009, 03:22 AM
Junster's Avatar
Junster Junster is offline
Default Re: Will this spark plug wire work?
I'm using Accel 8mm solid core hi temp. I slightly tapered the tip of the wire to help it get started into the CDI. I also lubed it with some silicone grease to help it go in. Just push hard as you screw it in. Mine has about 1500 miles on it with no problems. Oh and I marked the wire about 1/4" from the tip first so I knew I had it screwed all the way in.
Put something FUN between your legs..
