Old 08-22-2009, 01:06 PM
Junster's Avatar
Junster Junster is offline
Default Re: Need Perm Woodruff Key Fix. Popped out twice in 6 miles
Ok no offence but you do not adjust your idle with the cable. There is a spring loaded screw on the left side of the carb. Turn it in for a higher idle. It's engages a taper at the bottom of the carb slide. Use the cable adjust on the top to adjust the slack. You want it so when you lift the throttle cable housing/jacket where it goes into the carb with your fingers you have about 1/8" of play/slack before you feel the slide lifting.
Put something FUN between your legs..
