Thread: Blown Gasket
Old 08-21-2009, 11:40 PM
Mopedamauter79's Avatar
Mopedamauter79 Mopedamauter79 is offline
Default Re: Blown Gasket
Originally Posted by broHSI View Post
When did you change the bolts that hold the engine together?
Did you change all of them?
Replacing the case gasket will require you to split the cases which is a big job
and I doubt if any sealant will work to patch it up
Good luck
I did not change the bolt's I had tried to use what looked to be a better threaded bolt but it wouldnt go all the way in so I went back to the stock ones that came kit.I only drove it once as a test run and a very short distance with the one bolt almost all the way in. I may of blown the gasket then but it was loud right away not normal then suddnly loud so I don't know.
