Old 08-21-2009, 12:39 PM
RedB66's Avatar
RedB66 RedB66 is offline
Default Re: Need Perm Woodruff Key Fix. Popped out twice in 6 miles
The idle is just a matter of unscrewing the connection on top of the carb. At the pont where the cable goes in. loosen the adjuster until you reach the desired idle and then secure it back with the outer ring. You may be able to make the adjusment at the throttle handle also. This is what I mentioned when I noticed that the throttle had come loose during shipping. When you put the connection back on...if you didn't use the same amount of rotations that I did...the idle will be off.
