To tension or not to tension, that is the question?
meowy84
239
Canada
Putting my kit together and thinking of omitting the tensioner. I see bikes with and without one.
Personally I'm looking for a simple look and I think they tend to make the bike look more clattered and also the more components the more chances of it loosening and getting into the spokes. Since I have a chain breaker and my frame has some room for adjusting the back rim I should be able to eliminate most of the slack in the chain.
Just looking for some opinions from the MB gurus. Pros and cons.
taddthewadd
337
Visalia, California
I used to say it is better to run one without. Now I would say the only thing better is running a chain tensioner that is spring loaded. The reason I say this is if your sprocket is a little off center then when you rotate your rear wheel the chain will have a tight spot and get loose then tight over and over. This will make the chain break faster and make it easier for the chain to jump off of the sprocket.
There is a franchise store called tractor supply that sells a spring tensioner. Check their website. The spring is sold seperately so make sure you get both. The tensioner is nice it has a rubber roller and ball bearings in it.
The springed tensioner keeps the chain tension the same all of the time even if your sprocket is off center a bit.
happycheapskate
1,989
Rockwall TX
Here's the advice. If you run it without a tensioner, you will need some kind of axle puller/tensioners like what is found on BMX bikes, or you may get "axle creep".
If you want to do without a tensioner or roller, you will do best with a dedicated hub instead of the rubber sprocket holders.
Some frames don't have clearance and you will have chain slap or chain rub on the left chain stay.
Can I have your Roller tensioner? I like them, but I suggest welding them to the frame if you have narrow chain stays.
See my profile on motoredbikes.com for a chain tensioner I made from a go cart part, looks factory made.
bairdco
a guy who makes cool bikes
Aug 18, 2009
6,537
264
if you've got the clearance and install everything correctly, i think no tensioner is the way to go.
i've ridden with them and without them, and in my experience it's a smoother ride without it. and it definitely looks cleaner.
(edit) i've never had "axle creep" on any of my bikes, but i upgrade the washers and axle nuts, make sure they're tight, and that my chain's not too tight where it's gonna try to yank my wheel off. and, actually, i think my motor will move before my wheel does.
Cabinfever1977
2,288
Upstate,NY
I use the tensioner mainly as a chain guide, its like 2 feet from engine to sprocket on my cruiser, thats a lot of unguided chain without a tensioner or chain guide, one bump or chain shake and off the sprocket the chain goes and it would jam in the wheel and off the bike you go.
exavid
163
Medford, OR
I run my old Mesa Runner mountain bike without a tensioner. I had to modify the left side chain stay a bit to get enough clearance so the chain wouldn't touch. It works very well at least for the 200+ miles I've run it. As already mentioned you have to get your sprocket centered well or there will be some tightening and loosening of the chain as the wheel revolves. It only takes a few thousandths for this to happen. I've got a bit of variation in the chain tension as the wheel turns, it varies from about 1/8" slack to 1/2". That amount doesn't hurt. Checking the sprocket with a dial gauge shows a lack of concentricity of around .004". It doesn't take much. One other consideration is that I'm using a 15 speed bike if you're using a single or three speed setup it might be difficult to get the chains tensioned on both sides. It also helps if the dropouts are somewhat horizontal. I haven't had any axle creep at all so far. I did put star washers under both axle nuts.
rohan3ni
27
florida
try without it and see what happen . i kinda like a tension. made one myself and i find it really cool lol automatic tensioner lol
happycheapskate
1,989
Rockwall TX
If you can get a 415 chain to work that way (no tensioner or roller) , it might stay on. But the BMX and multispeed chains will start flapping at some RPMs and will derail.
tyrslider
958
RainCity
Use common sense 1st chain tensioner 2nd! if you've got horiz dropouts go w/o if not your stuck.
Bairdco is right (so very often)!
How come nobody (I think Bairdco was eluding to them) ever mentions axle nuts? You do know what axle nuts are, don't you?
