The one on the left the bolt/shaft coming out where the crankshaft is. I need to remove it and put the pulley on from the engine on the right
I think it's just a generic term for cantilever, unless the paint colors and scheme would indicate a Phantom origin?Rickenbiker,
Nice looking build and I agree that your in frame gas tank is much better looking than the peanut type of tank.
I have a question for anyone. When you say "Phantom" frame are you using one that was originally sold as a Phantom or is the term used more loosely to describe a vintage Schwinn cantilever frame as used on the Phantom, Wasp, Hornet, etc.? I know that those of us calling our straight bar framed Schwinns "Panthers" are using the term for any straight bar framed Schwinn. I'm guessing the same is true of the Phantom. Phantom is a lot more sexy than Wasp, for sure.
SB
Oh, yeah, absolutely! I've got 2 Green Phantoms...one a 100% original and very characterful '53 that's my restoration reference for my other, also a green '53, that's getting a ground-up, show restoration in my shop.No doubt you are right that the term is used in a kind of generic way for all the vintage cantilever framed Schwinns and it is certainly a well recognized name. On the other hand if you were to sit an original wasp or hornet next to a top end with all the doo dahs Phantom ... yeah, it is a looker all right. Kinda sexy as bicycles go. Woohoo!
SB
The shaft drive turns right off, threads are right hand not left.im not sure if the crankbolt is reverse thread or not......Ray would know
That is very nice! keep posting!The lock tab is not a foolproof way to tell a Phantom from "lesser" Schwinn frames. Although the presence of a tab is a sure indicator of a factory Phantom frame, the absence of a lock tab does not preclude it being a Phantom.
My Green Phantom was built by Schwinn for BF Goodrich and sold through their tire stores. It has neither lock nor tab.
The main issue with putting a gas tank in the horn tank's space in a cantilever frame is volume. The sculpted tank that I designed and fabricated is a full 2 1/2" wider than a stock frame horn tank, yet I am doubtful that it has the same capacity as even a tacky peanut tank. To use a stock horn tank as the outer shell, keep the horn button and still have decent fuel capacity is a big order...
