Rebuilt this SkyHawk GT 2, from top to bottom, but won't start!
Could it be I've not left ANY room for compression by only using Spray on, High Temp, Copper Gasket maker?
48cc.
Totally replace/torqued all bolts with steel.
Dax RT Carb.
NO air leaks anywhere.
Great compression (using finger-over-the-sparkplug-hole method).
Good spark with Jaguar CDI/COIL.
Brand new Mag/Coil/CDI/Cable/Plug,with GOOD spark (against Head).
Boost Bottle.
32:1 Mix on 6th tank. Ran great before old CDI went out.
ALL electrical wired right.
I have:
Good spark.
Great compression.
Fuel line clear/clean/32:1.
No Air Leaks.
After trying to fire up, and plug check, I have a wet plug (fuel reaching piston), and plug shows (tan/brown) evidence of firing.
BUT....
NO base gasket, no head gasket, JUST copper spray on.
Could it be I've not left/allowed enough room for anything to happen?
All ports polished/ported.
Help!
~CB
48cc.
Dax RT Carb.
Boost Bottle.
I have:
Good spark.
Great compression.
No Air Leaks.
BUT....
Help!
~CB
