Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motorized Electric Bicycles
wilderness controller question
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Electric Bicycles forum. i need to know if its possible to run hub motor kit without the controller.the controller merely controls the ...
Old 03-15-2008, 08:35 AM
Motor Bicycle Apprentice
Default wilderness controller question
i need to know if its possible to run hub motor kit without the controller.the controller merely controls the speed and wattage needed to power the hub isnt it?pls correct me if im wrong. i know theres more to it than what i explained bout controller's function.with the price of controllers and the frequency of fryin one out, i was thinking bout just using an 'always-open high amperage switch".just so i can just press the switch if i want to power up the hub.what are the downside of this setup?any help will be appreciated. ty.
Old 03-15-2008, 08:58 AM
CRUISER's Avatar
ADMINISTRATOR
Default Re: wilderness controller question
i am no expert but i believe it works like a dimmer switch so that being said you can use either a dimmer or on off switch. i dont see why you could just flick it to full power.
Old 03-15-2008, 02:10 PM
Bikeguy Joe's Avatar
I believe a member here, Deacon, has a bike or three he's set up like that.
Oh Deacon, where are you?
Old 03-17-2008, 12:03 AM
Norman's Avatar
LORD VADER Moderator
you could go with a push on and hold buttom but best to use it through a relay cause the amps drawn will need a heavy duty switch or it will warn up things that should not be warmed up. I'm not yet playing with the electric bike but getting interested in them I want to try a hub motor on the front and still have a gas engine. both would be fun 3 ways for power.
Pedals,engine,electric.
norms-iron-works.tripod.com
Old 03-17-2008, 08:36 AM
deacon's Avatar
They tell me it depends on the type motor. A motor with brushes does not need a controller to operate. A brushless motor has to have a controller to work. You can usually buy them on ebay and it depends on the watt of the motor and the voltage what to buy. At least that is my understanding.
visit my blog if you dare http://chinesekitmotorbike.blogspot.com/
Full novel on the blog in serial form.
