hmm... not that this is my area of expertise or anythin' lol - but when I was lookin' into electric/hybrid boats I noticed that many of the "rheostat" style throttles reduce voltage to the engine through resistance, which doesn't conserve power as it wastes it through heat generation. There's no real significant difference between say 1/2 throttle and WOT as far as battery drain is concerned.
Early designs worked around this wastage by stepping the voltage, tapping one battery for say 12v, two for 24, etc. this caused uneven power drain on the batteries in the bank ofc, but that was dealt with by periodically rotating the batteries so the same ones didn't always get all the load.
Newer throttle controls offer a pulse width modulated control signal which is far more efficient, conserving power at lower speeds but still using all the batteries uniformly - but they're expensive and as a result, not terribly common.
I have
no idea if this is common knowledge for you guys lol, most of the electric boat designs I was researching were the late 1800s to early 1900s
