running 24v controller at 36v I did this post because I thought I had learned something but now I'm not sure. My bike with the 7ah pack ran about three miles then started to shut down and come back. I finally came to the conclusion that it was low voltage and that the controller shut down based to the amps not the volts but now I'm not sure. The battery pack seems to have regenerated or I had a really bad connection. I am checking it out now but I wanted to change this post before I left the wrong impression with someone.
If anyone knows what a controller does when over powered as far as voltage shutdown I am curious to know now. I have based my rhino bike range based on the controller running to lower battery pack voltage because it is a 24volt controller. I will have to run more tests now and not rely on my intuitive thinking.
