Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motorized Electric Bicycles
Motorized Electric Bicycles The motorized electric bicycle is a quiet and efficient form of transportation for general commuting.
Need some basics
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Electric Bicycles forum. Well, I think my th!nk bike by ford is done aka busted. The electronics on it are just to ...
Old 06-25-2009, 01:01 PM
Default Need some basics
Well, I think my th!nk bike by ford is done aka busted. The electronics on it are just to complex to re-rig (shift lights, speed sensors, ect). I want to re do/by-pass all the electronics on it.
I have a bike, motor (think its 24v), gear box, new 24v battery pack, and 24v charger.
What I need is some sort of throtle control and battery life indicator. What do you guys use? What do you reccomend? Where can I purchase them?
Thanks!!!
Old 06-25-2009, 05:51 PM
deacon's Avatar
minor bike philosopher
Default Re: Need some basics
Tnc TNC Scooters (Scooter Sales and Service) can set you up with a controller and throttle. At the risk of preaching to the choir... the controller to match you motor and voltage is what you need. It will come with a circuit for a throttle. If yours is three wire you might be able to reuse it. It will also have a lock circuit and some other stuff you might be able to use. I don't know what your watt motor is but I was looking for a 24volt 500 watt and I think it was 20 bucks plus shipping. Also the throttle is about ten bucks if yours won't work.
Good luck...
Me and the Ebike
New Novel in progress blog...
Old 06-25-2009, 06:39 PM
Thanks. I just found out my motor is 250 watts and 24 volts... Are there any good controllers I should look at?
Old 06-25-2009, 07:33 PM
deacon's Avatar
To be honest at that size there are some really inexpensive ones on ebay now and then. I would check TNC first for a comparative price. I buy a lot from them and their stuff is all good. But I bought one from hong kong that seems to be okay as well. I only use the battery, motor and derailer circuits I tape the lock wires together. Actually I have lately begun to not even use them. For a 250 watt motor I would just go buy me a switch at the hardware store. You have everything you really need.
Pedal it a couple of times before you turn it on. Then it will just go wide open. At 250 watts you will want to run it wide open anyway. If it's a standard mount motor you might want to replace it with a high watt one. Of course then your battery consumption will go up.
your controller is the on off switch... You just run it like a pulse jet.
Good luck...
Ps if the electronics are fried, First thing I would do is to find the motor wires. Then it would test it with the new battery pack. Odds are petty good that the motor isn't cooked just the controller. If it is a 400 watt you might want to buy a controller since with a singer circuit on one so strong it will probably throw off the chain if you hit it with full throttle. Now I use an on off on switch and run one leg at 12v and one at 24 volts I start at 12v and then kick it up to 24
but then I'm a junk yard dog type builder
Me and the Ebike
