Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motorized Electric Bicycles
Motorized Electric Bicycles The motorized electric bicycle is a quiet and efficient form of transportation for general commuting.
My Bike
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Electric Bicycles forum. Hi here are som pics of my bike. It has an 84" wheel base, will run 30 mph on ...
Old 05-16-2009, 12:38 PM
metalmaster's Avatar
Default My Bike
Hi
here are som pics of my bike. It has an 84" wheel base, will run 30 mph on flat ground and has about a 12 mile range in the hilly terrain here in S.E. TN. It was built from a walmart mountain bike 14ga 1 1/4 tubing and some junk bike parts. The frame for the cargo basket is made from stainless and slips into the tube for the seat back, it can be removed in seconds wthout tools.The bike has a 36V battery pack and an onboard charger, also I have adapted a disc brake to the front wheel.
Jim
my-bike-0510091537.jpg  my-bike-0510091539.jpg  my-bike-0510091540.jpg  my-bike-0510091538.jpg
Old 05-16-2009, 01:25 PM
deacon's Avatar
minor bike philosopher
Default Re: My Bike
looks like a nice bike to me, and I think you might have discovered a good method to DIY an ebike. Start with someone else's and work from there. I like the idea of just using the wheel from an existing ebike. That is what you did isn't it? If not it sure gives me an idea.
Me and the Ebike
New Novel in progress blog...
Old 05-16-2009, 01:55 PM
Default Re: My Bike
Hi Deacon
thanks for the comments. To answer your question about the wheel no ebike parts used, the walmart bike was just the cheap $50 dollar mountain bike. I fabricated pretty much everything on this bike even the drive sprockets( I own a machine shop).
Jim
Old 05-16-2009, 02:28 PM
deacon's Avatar
Default Re: My Bike
Ah i see. way more talented than me but still the rear wheel thing from an ebike would really simplyfy things. I'll have to keep an eye out for a wreck.
Me and the Ebike
Old 05-17-2009, 12:14 PM
Default Re: My Bike
Yeah it would make things alot easier. It would be great if you could find something like one of those mongoose ebikes walmart was selling . Maybe with a blown controller or wrecked front end.
Jim
Old 05-17-2009, 06:15 PM
deacon's Avatar
Default Re: My Bike
Actually all the parts are available to rebuild one except the rear wheel elements. TNC scooter had the motor and controller and throttle, there isn't much else to one except that wheel with the extra freewheel.
Me and the Ebike
Old 05-18-2009, 05:45 PM
OzzyU812's Avatar
Default Re: My Bike
Do you need the throttle on a least a little all the time without a freewheel? Does it pedal OK without any juice to motor?
DAX 80f
Slanthead
NGK B7HS
SBP performance wire
44T
Stock Exhaust
32:1 cheap oil
no port matching
30 mph uphill!!!
Old 05-18-2009, 09:59 PM
Default Re: My Bike
Hi Ozzy,
I built this bike to be pretty much a pedal assisted electric.
There is quite a bit of drag from the motor when pedaling alone, you sure wouldn't want to pedal it too far. In an emergency it would be fairly easy to pop the master link off the drive chain to eliminate the motor drag. This bike has been a test mule for different ideas and I have a more powerful motor that has a freewheel on the drive sprocket I just haven't gotten around to reworking the drivetrain setup.
Jim
  #9 (permalink)
Old 05-26-2009, 10:27 PM
Cabinfever1977's Avatar
Default Re: My Bike
im making a elctric bike out of a old roadmaster bike.
i have all parts available from a mongoose e-bike from walmart.
front wheel 18" and a 16" rear wheel with sprockets(i will put this on mountainbike)
i will change the front fork on the mountainbike with the one from mongoose for the smaller wheel and the brakes will work.i will mount motor on rear rack and run chain down to sprocket. i will mount battery pack with controller in v-frame part(plus i have the charger for it)i also have the throttle for it too.and i will be able to peddal it too.
it should be good for 15mph for a short distance(with new battery it would get 5 miles but now that its old it will probally get less).i will post pics sometime.
updateroject delayed,back wheel too wide for mountain bike.
