STEP ONE
strip donor bike
First you will probably need to remove the chain guard. Cheap plastic headed for the land fill. Mine was held on with a couple of Phillips screws.
Then you will need to loosen the bolts holding the rear wheel on. I found a couple of dropout locks as well. You might need to completely remove the bolts and any other hardware holding the rear wheel in place. Remove the brake lever clamp so that the wheel will move freely.
Move the wheel in the drop out slots until the chain is loose. Work the wheel out of the drop outs.
At this point it should look like this....
Next you should remove the brake lever... at that point you wheel will look like this..
Use your chain breaker to push out one of the rivets in the chain. I push mine ten half turns and then twist the chain. This should leave the rivet hanging so that you can use it to reuse that chain later.
At this point you can toss the rest of the bike if you want to. I however always junk it out as much as possible. For instance on twenty inch bikes and up the cranks are mostly interchangeable. Why would you want to? On a motor bike pedaling is secondary. The shorter pedal arms make it much more convenient for me. However on a sixteen inch bike they usually are not interchangeable so I didn't bother.
I pulled the handlebars and the goose neck from the bike. Those high rise handle bars are good to use if you need to sit low on the bike for balance and your knees hit on a regular handlebar. Mine always hit on a mountain bike it seems. I also pull the front wheel since the spare tire and tube are good to have around. It's easier to pull the whole thing than to remove the tire. I also pull the seat and post. The seat is too small for sure but the mounting hardware under the seat is pretty universal.
At this point I put the frame out for the metal junkers to pickup. If I still drove I might take it to the crusher myself. I expect doing that you can more than repay yourself for the purchase of a donar. For instance the rear wheel is about thirty bucks. The chain is over five... The front wheel is probably the same. You also have the equivalent of one new tire (between the front and rear ones) and a couple of good tubes if you are lucky. The seat hardware and handlebars are worth something down the road. In other words it was a good buy so far.
I shot this before I added the handlebars and goose neck to my stash.
