| | | Motorized Electric Bicycles The motorized electric bicycle is a quiet and efficient form of transportation for general commuting. | Battery battery, who's got the battery dope Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Electric Bicycles forum. I am trying to make a basic decision here today. I want more range but I do not want huge ...  | |
08-25-2009, 09:02 AM
|  | minor bike philosopher | | Join Date: Jan 2008 Location: north carolina
| | Battery battery, who's got the battery dope I am trying to make a basic decision here today. I want more range but I do not want huge battery packs. So I'm rethinking my choices.
Now I know that I can run either bike on 24 or 36 bolts. The range on the bikes does not change. I am simply adding power with the third battery. A good compromise power setup is five hundred watts no matter what the configuration. Ie a five hundred watt motor at 24 volts is about the same as a 350 watt motor at 36volts. If you watch ebay and take your time you can buy a 500 watt motor for about the same price as a 350 watt motor.
If I went with the 500 watt at 24volts what would I lose. I would lose speed of course but I seldom use that speed anywhere but for climbing hills. The 500 watt at 36 climbs like a mountain goat and at a decent speed. It runs very close to the stock china bike kit in most ways. A little slower but with the same torque I think.
I am really torn here... I can not justify the higher price of the lith poly packs. So do I go back to the 24v pack and sacrifice the speed or just bite the bullet and redesign the trailers so that I can pull both battery packs to add a couple of more miles range.
Has anyone else been faced with t his decision?
08-25-2009, 10:29 PM
| | Motorized Bicycle Elite Member | | Join Date: Apr 2009 Location: MA
| | Re: Battery battery, who's got the battery dope Deacon,
What type and size AH are you now using on your 24/36v setup? Are you using a hub motor?
Russ |
08-25-2009, 10:40 PM
|  | Motorized Bicycle Elite Member | | Join Date: Feb 2008
| | Re: Battery battery, who's got the battery dope Quote:
Originally Posted by deacon I am trying to make a basic decision here today. I want more range but I do not want huge battery packs. So I'm rethinking my choices.
Has anyone else been faced with t his decision? | I'm not hearing much good about the LIfepo4 lithium packs. They seem to sometimes just stop working.
Here's a battery that will end all your troubles. http://www.advancedbattery.com/mmABS.../24V20T4LT.gif |
08-26-2009, 06:59 AM
| | Re: Battery battery, who's got the battery dope I have a hub motor that I never use at all. I don't like it. I run ebikes that I build from parts that are used for other things. The one I am running at the moment is the rear wheel of a scooter sitting on top of the rear wheel of a bike. Powered by a 500 watt scooter motor using a #25 chain drive system. I used the same set up with 16 inch kids bike rear wheels at a pusher trailer.
I have decided to go with the speed. One battery pack is a 36v (3) 12v 12ah batteies and the other is the same but with 7ah. I have decided to use each alone the piggy back them if I need a longer range. I also pull the batteries in a trailer made from the front wheels of a couple of scooters. They are housed in a small plastic tool box from dollar tree. The 12ah fit perfectly.
When I next buy I am going for the 20 ah batteries I think. With the two packs I can ride a short trip to the park then switch out the packs while it charges I can go to the store. When I get back from the store a couple of hours later I have enough power in the small pack to ride to the shopping center a few blocks away. I could do that most all day but two 20 packs would be the cat's meow.
I always wondered about the lith poly because there are so many wiring connections in the pack. The ones I have seen look as though they are put together by a bunch of guys sitting on a dirt floor in china.
08-26-2009, 05:28 PM
I know nothing about lith batteries, I use a 24v wheelchair motor. I run it through the gears on my 10 speed. However due to the fact that I tie up one fo my crancks two sprockets I only have 5 speeds. I am using two lawn mower battries, I have not been able to find the AH capacity of them. However for the limited use that I put on them they have served me well, but yes they are heavy and bulky BUT CHEAP! I would ASSume they are about 30 AH. The motor draws 10/25A depending on gear and load.
Thank you for the info. Quote:
Originally Posted by deacon I have a hub motor that I never use at all. I don't like it. I run ebikes that I build from parts that are used for other things. The one I am running at the moment is the rear wheel of a scooter sitting on top of the rear wheel of a bike. Powered by a 500 watt scooter motor using a #25 chain drive system. I used the same set up with 16 inch kids bike rear wheels at a pusher trailer.
I always wondered about the lith poly because there are so many wiring connections in the pack. The ones I have seen look as though they are put together by a bunch of guys sitting on a dirt floor in china. | |
08-31-2009, 12:40 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jan 2008 Location: Arizona Bullhead
| | Re: Battery battery, who's got the battery dope Have you looked at this site. 24VDC 600W MOTOR, 15T W/CLUTCH | AllElectronics.com
They have controllers throttles brakes sprockets motors that use belts ,chains or just a dee shaft
Motorized bicyclist
08-31-2009, 01:24 AM
Originally Posted by spad4me | That motor looks like it might be a good buy, but what is a "roller clutch" sprocket? And will standard bicycle chain fit on a #25 sprocket or would I need to take it off and mount another sprocket? |
08-31-2009, 06:12 AM
| | Motorized Bicycle Member | | Join Date: Jul 2009 Location: massachusetts
| | Re: Battery battery, who's got the battery dope No, #25 chain is smaller than bicycle chain. You might be able to use it as the 1st stage of a 2 stage reduction unit, however. AllElectronics sells a separate roller clutch sprocket that freewheels in one direction so I assume that is what the roller clutch on the motor is. They also sell an interesting looking planetary gear reduction unit for $9.50 PLANETARY GEAR | AllElectronics.com |
08-31-2009, 08:27 AM
| | Re: Battery battery, who's got the battery dope I couldn't figure out the shipping without placing an order for the motor. Does anyone know what their shipping is. |
08-31-2009, 01:05 PM
Originally Posted by jdcburg No, #25 chain is smaller than bicycle chain. You might be able to use it as the 1st stage of a 2 stage reduction unit, however. AllElectronics sells a separate roller clutch sprocket that freewheels in one direction so I assume that is what the roller clutch on the motor is. They also sell an interesting looking planetary gear reduction unit for $9.50 PLANETARY GEAR | AllElectronics.com | Your motor already has a gear reduction, no way I'd use another gear reduction on top of that. You were able to use bike chain and said what sprocket you used and where you got it, but I didn't understand what you meant by using washers as shims and having to alter it. The sprocket didn't fit onto the shaft out of the box? | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:40 PM. | | | Sponsors
