Originally Posted by deacon Before I buy a new sprocket for my ebike I just built I want to be sure I have the right thing in mind.
When i go uphill with the motor my bike will not respond to the throttle at all after a certain point. I am thinking about getting a bigger sprocket to get more torque. Motor and controller and throttle all work and are set up for maximum efficiency. I need to get the most out of my sprocket. I am running a 65 tooth sprocket now. I am considering going with an 80tooth.
So what do you think? Should I go eighty tooth or just live with the bike the way it is. |
A bigger sprocket of course will add more torque for hills, that is if this is the problem to start with. And if it is, a 15 tooth increase is a huge increase in a sprocket size. It should climb a wall if that's what the problem really is.
