Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Whizzer Motor Bicycles
Whizzer Motor Bicycles Whizzer motorized bicycles are still produced today, and one of the oldest motor bikes around. Share some of your stories about this timeless classic with us today
Tillotson MT series question
Discussion at Motorized Bicycle Engine Kit Forum in the Whizzer Motor Bicycles forum. I got everything together today, and wanted to check for any leaks between the tank and the carb, (tank, Tillotson ...
Old 02-08-2009, 10:24 PM
Buzz Bomb's Avatar
Default Tillotson MT series question
I got everything together today, and wanted to check for any leaks between the tank and the carb, (tank, Tillotson fuel bowl, line, Tillotson MT series carb). The carb was supposed to be tested good. Anyway, I put a bit of gas in the tank, opened the bowl valve, let the fuel fill the float chamber, and a minute later fuel ran out of the barrel(venturi) and onto the garage floor in a fast drip. Somebody said that this is normal. Bad needle valve in the float chamber? That cant be right.
Last edited by Buzz Bomb : 02-09-2009 at 02:05 AM. Reason: something bizzare happened and deleted half of the post.
Old 02-09-2009, 03:08 PM
Bikeguy Joe's Avatar
Default Re: Tillotson MT series question
Tap the chamber, sometimes the float may stick.
Other than that, the tip of the fuel shut off needle could have crud in it, or it's worn or bad.
Old 03-04-2009, 10:04 PM
Whizzer Nut's Avatar
I have the same set up. (46 H with Tillotson & glass fuel bowl) I can let the fuel turned on for days & it will not leak. I would think the needle & seat is sticking, dirty, or float problem. Float height may need to be set. Theese carbs are as simple as it gets, so it should be an easy fix. I would start with cleaning carb bowl & needle & seat. Good luck & keep Whizzin, Dan
A.K.A. Likemyspoiler
Old 03-04-2009, 11:06 PM
Quenton Guenther's Avatar
Dealer
Hi,
If the needle valve & seat are good, and the float level is set correctly it shouldn't leak. I have however noticed a few leaking if the bike is tiltled to one side too much [using bike kick stand]. A friend of mine has a '47 with an "H" motor and we have messed with the float, replaced the seat and shut off [needle valve], and it always manages to leak on the kick stand, but never otherwise.
Have fun,
Quenton
