Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Whizzer Motor Bicycles
Whizzer Motor Bicycles Whizzer motorized bicycles are still produced today, and one of the oldest motor bikes around. Share some of your stories about this timeless classic with us today
AX27 Belt
Discussion at Motorized Bicycle Engine Kit Forum in the Whizzer Motor Bicycles forum. Hi New to this forum, has anyone had this probem with AX27 belt rubbing the bottom part of the belt ...
Old 08-21-2009, 11:17 PM
Default AX27 Belt
Hi New to this forum, has anyone had this probem with AX27 belt rubbing the bottom part of the belt guard posts.My bike is a whizzer 2000 WS24 Sportsman.Bike is original with slip clutch and NE up grades.Belt is a JASON AX27 Raw Edge Cogged Belt.THANKS
Old 08-24-2009, 09:03 PM
Fossil's Avatar
Default Re: AX27 Belt
Yep I have with my upgraded 2000 WC-1. It's a pretty common problem. I bought the belt tentioner kit from Whizzer. I am even using it with my auto clutch and it works great.
Whizzer Motorbike
It is pricey but it solved my belt issues. The only other way you can get around the problem is to find a 28.5 inch belt. The AX-27 is a 29 inch belt. The shorter belt will pull the pulley down farther and then the belt will clear the mounting posts.
Good luck.
Jim
PS This picture is from a very respected Whizzer expert. Quenton Guenther. Thanks Lee
EZ Motorbike Distributor / Dealer Guthriesville Pa
Last edited by Fossil : 08-24-2009 at 09:28 PM. Reason: Improved grammer so I don't look stupid.
Old 08-24-2009, 11:06 PM
Thanks Fossil, I just took off belt tentioner with 4L290 belt was hoping to used less parts.Im going to keep the slip clutch,I have Auto clutch on my 99
Old 08-24-2009, 11:10 PM
Fossil's Avatar
That's great you have a tentioner. They say it is only for the slip clutch but I still use it on my autoclutch. I don't have any problems using it with either setup. It should have been standard on all Whizzers.
Jim
Old 08-24-2009, 11:13 PM
