| | | Whizzer Motor Bicycles Whizzer motorized bicycles are still produced today, and one of the oldest motor bikes around. Share some of your stories about this timeless classic with us today | 99 Whizzer Brake light fix Discussion at Motorized Bicycle Engine Kit Forum in the Whizzer Motor Bicycles forum. Has anyone else done this? My 99 has the brake light switch working off the coaster brake arm. I laced ...  |
05-21-2009, 06:09 PM
|  | Motorized Bicycle Elite Member | | Join Date: Oct 2008 Location: Lebanon, Pa.
| | 99 Whizzer Brake light fix Has anyone else done this? My 99 has the brake light switch working off the coaster brake arm. I laced up a Shimano hub but my brake light switch works off my coaster brake arm. The arm won't fit my Shimano hub. The 99 arm has a slot in the arm & the Shimano brake is kind of like a spline (yes I should have taken pictures). I thought I'd clamp them in a vise & file out the Whizzer arm to fit the spline shaft on the Shimano hub. I did that to a Harley sprocket years ago because I wanted lower gearing than was available. Well, this Whizzer coaster brake arm was hard steel. Real hard. So I heated it with a little propane torch & let it sit overnight & the next day it filed easy. Now my Bike has the Shimano hub & brake lights.
EZ Motorbike Dealer
08-21-2009, 08:26 PM
| | Re: 99 Whizzer Brake light fix Doesn't anyone have a Whizzer? There haven't been any hits on the Whizzer site for days. About the rear brake switch. This might show how much I don't know but, I just realized that the front brake lever has a little brake light switch in it. So that means we don't have to worry when we change back brake hubs. Take off the coaster brake light thing & if we use the front brake lever (which we all do) the rear brake light will come on.
Jay
EZ Motorbike Dealer
08-22-2009, 12:19 AM
|  | Dealer | | Join Date: Dec 2007 Location: Sacramento
| | Re: 99 Whizzer Brake light fix Hi Jay, the little switch can be had, and put on your clutch lever, NOW anytime you pull in the clutch, you WOULD be slowing down?
I like it like that!
Mike |
09-23-2009, 08:31 PM
| | Re: 99 Whizzer Brake light fix Mike, That's a great idea!! Where can I purchase that little switch?
Jay
EZ Motorbike Dealer
09-23-2009, 11:44 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2009 Location: Mi
| | Re: 99 Whizzer Brake light fix Quote:
Originally Posted by MotorbikeMike Hi Jay, the little switch can be had, and put on your clutch lever, NOW anytime you pull in the clutch, you WOULD be slowing down?
Mike | Actually there's a few times I pull in the clutch and I speed up.
Anyone have a picture of how the Whizzer coaster brake light switch is set up? I just can't get my mind wrapped around how a switch is connected to the coaster brake arm. I'd like to set something like that up on my bike. |
09-24-2009, 09:48 PM
| | Re: 99 Whizzer Brake light fix Here are some pics of the rear brake light switch.. Hope they're clear enough to see. It's easier though to just buy a front brake lever with the switch built in if you have a front brake.
EZ Motorbike Dealer
Reason: more info
09-24-2009, 10:27 PM
| | Re: 99 Whizzer Brake light fix Thanks jbcrusin I think I can fab up something like that.  |
09-27-2009, 10:14 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: St.Louis, Missouri
Originally Posted by jbcruisin Has anyone else done this? My 99 has the brake light switch working off the coaster brake arm. I laced up a Shimano hub but my brake light switch works off my coaster brake arm. The arm won't fit my Shimano hub. The 99 arm has a slot in the arm & the Shimano brake is kind of like a spline (yes I should have taken pictures). I thought I'd clamp them in a vise & file out the Whizzer arm to fit the spline shaft on the Shimano hub. I did that to a Harley sprocket years ago because I wanted lower gearing than was available. Well, this Whizzer coaster brake arm was hard steel. Real hard. So I heated it with a little propane torch & let it sit overnight & the next day it filed easy. Now my Bike has the Shimano hub & brake lights.
__________________ | Nice
And would like to see some overall pics   | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:34 AM. | | | Sponsors
