| | | Whizzer Motor Bicycles Whizzer motorized bicycles are still produced today, and one of the oldest motor bikes around. Share some of your stories about this timeless classic with us today | 2002 Whizzer, are they okay? Discussion at Motorized Bicycle Engine Kit Forum in the Whizzer Motor Bicycles forum. I've been considering buying a 2002 blue Whizzer, but I'm not very
familiar with engine problems or other ...  |
04-27-2009, 07:27 PM
| | Motorized Bicycle Senior Member | | Join Date: Dec 2008 Location: Atlanta, Georgia
| | 2002 Whizzer, are they okay? I've been considering buying a 2002 blue Whizzer, but I'm not very
familiar with engine problems or other problems or changes that I
should be aware of.
I currently have a 2 stroke 80cc engine powered cruiser with front and
rear drum brakes, but I'd rather have a 4 stroke. I think it would be
more cost effective to just buy a good Whizzer and improve on it from
there. What's the top realistic speed on a Whizzer anyway? They don't
vibrate your brains loose do they, like these 2 strokes? |
04-27-2009, 10:50 PM
|  | Motorized Bicycle Elite Member | | Join Date: Oct 2008 Location: Urbandale Ia
| | Re: 2002 Whizzer, are they okay? It's just all in how much you want to spend, and what kind of riding you are doing. I am sure the Whizzers would be a little more reliable, but it comes at a huge price difference.
If I was using it for my main transportation and not just as a hobby I would buy a motorcycle.
John |
04-28-2009, 02:31 AM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: Mesa, AZ
| | Re: 2002 Whizzer, are they okay? My whizzer will cruise at 40mph. They have very little vibration except at idle it lopes a little like a Harley. I love mine! |
04-28-2009, 05:50 AM
| | Re: 2002 Whizzer, are they okay? Thanks for the feedback. I've owned and ridden motorcycles for over
22 years, I guess that's why I'm drawn to these motorized bikes. My
first build that I completed in March this year is a 2 stroke as I mentioned earlier, and I was surprised at the amount of vibration,along with low power that it has. So, being more familiar with 4 stroke engines I'm considering installing that instead,or
consider buying a good used Whizzer and that's where I'm at, at this point. The
cost to upgrade my Della Cruz bike has escalated quite a bit too, so I'm trying to
make a good choice.Thanks,
Fred
04-28-2009, 07:36 PM
|  | Dealer | | Join Date: Dec 2007 Location: Sacramento
| | Re: 2002 Whizzer, are they okay? Hi on that 2002 Whizzer, you need to check and see if the engine has been upgraded to NE5 level, if not, it will surely need that.
Fell free to ask questions, or contact me directly.
Mike |
06-16-2009, 10:22 AM
|  | Motorized Bicycle Elite Member | | Join Date: Oct 2008 Location: Tampa Bay, FL
| | Re: 2002 Whizzer, are they okay? Ne5 Level ????
sorry, I'm just starting to research Whizzers... =-]'
'BrettMavriK |
06-16-2009, 08:50 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2008 Location: Lancaster County, PA
| | Re: 2002 Whizzer, are they okay? The 1999 through 2004 Whizzers were built with the WC-1 engine, which has an inherent flaw in the design of the cylinder. The valve seats will ultimately come loose, more likely sooner than later. There really is no way to fix this once it happens, except to convert the engine to NE5 configuration using the NE upgrade kit. This is expensive, but it keeps your Whizzer from becoming a 100lb paperweight.
EZ Motorbike Dealer - Quarryville, PA
07-06-2009, 12:53 PM
|  | Dealer | | Join Date: Feb 2008 Location: Outer Banks of North Carolina
| | Re: 2002 Whizzer, are they okay? I have a few [very few] NE cylinders in stock. The main parts needed to convert the WC-1 motor to the NE version are the cylinder, head [different bolt pattern], head bolt kit, exhaust spacer, and various gaskets. The average cost for the Whizzer upgrade kit is $466.xx plus shipping. I have been supplying the needed parts for $375.00 plus shipping. The NE upgrade kit includes several parts not needed or doesn't work correctly. The kit has the larger 22 MM carburetor, however the carburetor is too large unless you install the NE camshaft [$106.30], and the carburetor doesn't have a breather. The kit also includes a piston & rings, not needed because the WC-1 doesn't go far enough to need a new piston & rings. The kit also includes an exhaust manifold that fit the new larger pipe and won't fit the original WC-1 pipe correctly.
Hope this information is helpful,
Quenton EZ MOTORBIKE COMPANY | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:15 PM. | | | Sponsors
