Stock Market Cats Alternative Energy
Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Wide Engine Mount Spacer
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. Guys I need a 2 inch wide mount spacer. Does anyone know what vendor sells this? I need a wider ...
Old 01-24-2010, 06:39 PM
Kevron99's Avatar
Default Wide Engine Mount Spacer
Guys I need a 2 inch wide mount spacer. Does anyone know what vendor sells this? I need a wider mount to space into my front mounts. I have check all sites that I know off including e-bay they all measured to 1.5 inches only. Desparately needs help. Any suggestion is highly appreciated. Thanks
Old 01-24-2010, 08:12 PM
PaulFlorida's Avatar
Default Re: Wide Engine Mount Spacer
for 35 bucks, Jim at creative engineering had a fantastic mount set up. He's on the side bar to the left
Old 01-24-2010, 08:32 PM
Kevron99's Avatar
I know Jim' mount. But I am using it for mounting an engine with a jack shaft.
Old 01-24-2010, 08:34 PM
Salty Gator's Avatar
I'm planning a road trip first week of Feb. for the exact mount you speak of Paul....I'm 2.5 hours north of Jim and figured I'd pay less for gas than I would shipping since I'm also going to be purchasing his sprocket and adapter as well as his intake....I spoke with Jim on the phone this week and he said " come on down ! ".....his mounts are the bomb !
Salty
Old 01-24-2010, 08:36 PM
Call Jim and see what he says about his mount working with a jackshaft.....there's bound to be a way to utilize it .....
Good luck,
Salty
Old 01-24-2010, 08:40 PM
Gas Bike sells a universal mount that will fit 99% of the frames out there ....I bought one myself and it works just fine.....www.gasbike.net
Salty
Old 01-24-2010, 08:41 PM
Kevron99's Avatar
Yeah...Thanks Salty. But all I need is a spacer since there was an inch and a half gap between my motor and my custom front mount from Ridleys.
Old 01-24-2010, 08:54 PM
You're welcome Kev and sorry I can't be of more help....Have you considered a machine shop fabricating one for you ?.....a small piece such as that shouldn't be too pricey......
Salty
Old 01-24-2010, 09:06 PM
Cabinfever1977's Avatar
im sure you can make one yourself.
Old 01-24-2010, 10:56 PM
2door's Avatar
Kev,
Do you mean 'wide' or 'thick'? I consider the width to be the distance from side to side. The bolt centers are only about 1 5/8" inches so you couldn't open up the saddle, semi-circular portion to 2". If you mean the thickness, from the engine case to the seat tube center, then fabricating a 1/2" spacer shouldn't be difficult. A piece of scrap aluminum should be easy to find or even your local Ace hardware has 1/4" aluminum that you could stack to give you the extra 1/2" you need.
Over Youth and Skill
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
