Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Weed Wacker Mounting Idea
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. If you mount the motor on a swiveling joint , lets say about 3 or 4 inches in front of the ...
Old 09-21-2009, 08:07 PM
diceman2004's Avatar
Default Weed Wacker Mounting Idea
If you mount the motor on a swiveling joint , lets say about 3 or 4 inches in front of the centerline of your wheel , just the force of the drive roller spinning against the tire will push your roller onto the wheel .
if you are too far from the centerline , it will just rub
too close to the centerline , it will ride off the back of the wheel .
something like this could use an old ten speed shifter lever to easily raise the roller off the wheel
Old 09-25-2009, 11:40 AM
Default Re: Weed Wacker Mounting Idea
Sounds very intriguing. I have mounted my friction drive on a swivel. It works well but is much more complicated than I understand your suggestion.
Can you clarify how you would engage/disengage the motor?
Old 09-25-2009, 12:34 PM
C-MON don,t make me do all the thinkin .
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f6/weed-wacker-mounting-idea-11418.html
Posted By For Type Date
Weed Wacker Mounting Idea - Motorized Bicycle Engine Kit Forum | Bicycling Leisure Knowledge This thread Pingback 09-22-2009 04:07 PM
