Spring Return Chain Tensioner
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. I was having a problem keeping my chain taut, and was very unhappy with the stock chain, so off to ...
Old 05-02-2008, 06:39 PM
misteright1_99's Avatar
Default Spring Return Chain Tensioner
I was having a problem keeping my chain taut, and was very unhappy with the stock chain, so off to Tractor Supply for some #41 chain. Got the chain and got to browsing and also picked up a really sweet ball bearing, rubeer coated chain trensioner, AND spring, it is sold seperatly. After mounting the chain I took some 3/8 althread rod, heated it up and bent it into a U shape to fit around seatpost. I cut a strip of metal ( out of stock tensioner mount) to secure allthread. Then I just mounted the spring tensioner to the end of the allthread, the ID of the tensioner seems to be a good fit on 3/8" rod. Then a little adjustment and done. Spent $40. on everything including new chain. I have put a couple of miles on it an it is a lot quieter, and very smooth...
spring-return-chain-tensioner-may-2008-008.jpg  spring-return-chain-tensioner-may-2008-009.jpg  spring-return-chain-tensioner-may-2008-010.jpg  spring-return-chain-tensioner-may-2008-011.jpg  spring-return-chain-tensioner-may-2008-012.jpg
Old 05-02-2008, 07:35 PM
fairracing31's Avatar
Default Re: Spring Return Chain Tensioner
Great set up! That look's great
That's kind of what I used for my Dble. suspension bike. I do not have pic's of it. But here is what I used. I used a Idler sprocket and had to do some mod's to get it to work with the tensioner. Your set up look's much better.
spring-return-chain-tensioner-ch4j-singcopy2.jpg  spring-return-chain-tensioner-13633_lg.gif
Old 05-02-2008, 08:39 PM
I looked at those tensioners and was about to order one Fair, when I saw the one at Tractor Supply. It looked like a lot of mods to make it fit my bike though. And the one at TSC was less than $15. with spring.
Old 05-02-2008, 08:53 PM
Yes, it took alot of mod to work, and it was'nt cheap. But at the time I had a nissan timing chain tensioner that I was using. I was taking a trip to Mexico and there was no way I was going alone. The homemade nissan tensioner had a little to much tension on it because that was the only way I could keep the chain to stay on on the trail. And I was afraid to take a long trip with the way I had it set up. So it was kinda of a last minute set up I did with the tensioner and idler sprocket, but it worked great, held up all they way. The chain did fall of several times.
Your set-up is much better and I like it. I was looking at tractor supply but could not find it
Old 05-02-2008, 09:25 PM
Yea I dont see the parts either. looks like they carry them for their line of mini bikes "Baja Motorsports". You could call them. the part # is 165-063 for the chain tensioner, and # 165-280 for the spring...
Old 05-03-2008, 08:12 PM
jezusjonz's Avatar
I love that George thanks for sharing that. I tell ya thats the one thing I hate so dearly on these is that tensioner. Well you know I ditched both of mine but I would rather be running them. Might have to make a trip to TSC and thanks for the part numbers.
Terry
Old 05-03-2008, 08:16 PM
Well Terry your bikes look so awesome this would be a good way to take care of chain slack and be somewhat hidden. The stock tensioners look ALMOST as bad as they work.
Old 05-23-2008, 09:47 PM
CRUISER's Avatar
ADMINISTRATOR
very nice mister right. i been in the middle of a move and missed this all togather. i am putting a copy in the clasic posts area
http://stockmarketcats.com/
  #9 (permalink)
Old 05-23-2008, 10:10 PM
Thanks Cruiser. Everyone here has been soooo helpful, and by reading and looking I have found so many great ideas. I felt I should contribute some. Great site.......
Thanks Again.......
  #10 (permalink)
Old 05-29-2008, 08:56 AM
filestyle1's Avatar
what is the actual type of spring that you used?
I'll keep rollin "FileStyle"
Similar Threads
chain tensioner mod (in response to norman) astronut Motorized Bicycle General Discussion 15 05-23-2008 03:56 PM
Chain Tensioner Easy Rider High Performance Bicycle Engine Tips 5 05-08-2008 11:16 AM
chain tensioner modification Norman Motorized Bicycle General Discussion 11 05-06-2008 04:59 PM
Solved this whole chain tensioner thingy jhey Motorized Bicycle General Discussion 12 02-24-2008 04:35 PM
Cupped washers for chain tensioner Bikeguy Joe Bicycle Engine Kits 7 02-20-2008 06:56 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
