| | | Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack | Spring Return Chain Tensioner Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. Originally Posted by Rynos63
Nice catch... I just noticed that... Thanks
Glad to help! Love the set-up, too, BTW....  | |
06-05-2009, 01:43 PM
|  | Motorized Bicycle Senior Member | | Join Date: May 2009 Location: Brookston, IN
| | Re: Spring Return Chain Tensioner Quote:
Originally Posted by Rynos63 Nice catch... I just noticed that... Thanks | Glad to help! Love the set-up, too, BTW. |
06-05-2009, 10:28 PM
|  | Motorized Bicycle Newbie | | Join Date: Nov 2008 Location: Strathmore, Ca
Originally Posted by Norco John Glad to help! Love the set-up, too, BTW. | Thanks.... |
06-08-2009, 02:31 AM
| | Re: Spring Return Chain Tensioner I know if you need to clear the lower wheel stay then you have to use a tensioner. But if you can get away without one it's alot better. An aluminum shim behind the rear mount works great. It doesn't take alot if you get it close with or without a half link.
__________________ Put something FUN between your legs.. |
07-01-2009, 02:38 PM
|  | Motorized Bicycle Elite Member | | Join Date: Apr 2008 Location: Valparaiso, IN
| | Re: Spring Return Chain Tensioner -Like I said about 3 months ago, I have had the arm, roller and spring for some time (over a year)- just got around to putting the tensioner together last night. Works well, look good. However, I am taking it apart and changing a couple of things. First, I used a 5/16" U-bolt as it was pre-bent, the right size and plenty strong enough. I like the look of npt having threads all the way around, but that's just me. I also have obtained a 1 1/8" muffler clamp. I am going to use the saddle from it as That will secure the u-bolt better. Probably unnecessary, but nearly everythin on my bike is. there are a couple of other things, but I will post pics shortly which will do a better job of explaining it.
Thanks for the idea! |
07-01-2009, 03:53 PM
|  | Motorized Bicycle Senior Member | | Join Date: May 2009 Location: East Wenatchee, Wa
| | Re: Spring Return Chain Tensioner I fabricated a spring loaded tensioner this weekend and it looked great but I am having a strange problem. When I am coming down a hill under no power my chain jacking (the chain slapping up and down) is so bad I can feel it and hear it stressing out the clutch and it was so bad I removed my fabricated tensioner and went back to my original. Has anyone had this problem?  |
07-01-2009, 05:11 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: upstate NY
| | Re: Spring Return Chain Tensioner maybe you need a stronger,shorter, or tighter spring. |
07-01-2009, 05:27 PM
| | Re: Spring Return Chain Tensioner I tried two different lengths of springs and strong springs and soft springs and got similar results. It seemed to be worse when I used stronger springs. Perhaps I should try applying the tension to the top of the chain and not the bottom of the chain and see if that helps. I also noticed that when i put pressure on the chain with the tensioner that the clutch became really loud!  |
07-01-2009, 11:11 PM
| | Re: Spring Return Chain Tensioner i use my stock tensioner. besides the 2 stock bolts on tensioner i also have a bolt behind the tensioner held in place by 2 hose clamps that keeps the tensioner from moving at all. |
07-02-2009, 10:34 AM
| | Re: Spring Return Chain Tensioner Here is my version of the tensioner. It is based on Misteright1_99's design, but with my own tweaks. As you can see, i still use the original tensioner for chain gudance as i need to to maintain clearance. |
07-02-2009, 05:24 PM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: Los Osos, California
| | Re: Spring Return Chain Tensioner To HoughMade, - that is a cool bike.
I was skeptical of spring loaded tensioners on these bikes since the chain is also used to start the engine and that switches the tight side of the chain over to the tensioner for a brief period. When that happens the spring loaded tensioner/guide gets displaced and the chain may jump the sprocket. Your design solves part of this problem by adding a second roller as a tensioner and retains the original chain tensioner to act as a guide to minimize that problem.
If someone does run a single spring loaded chain tensioner, make sure the spring is strong enough so that the compression braking does not make the chain go slack. It may still go slack when you start the engine, but as long as it does not jump off, you should be OK | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:48 PM. | | | Sponsors
