Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Spring Return Chain Tensioner
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. Originally Posted by Rnroutlaw My chain tensioner broke on my third test ride. So I simply took 4 links out ...
  #51 (permalink)
Old 04-10-2009, 08:33 AM
commander's Avatar
Default Re: Spring Return Chain Tensioner
Originally Posted by Rnroutlaw View Post
My chain tensioner broke on my third test ride. So I simply took 4 links out of my chain and of I went. My chain has become a bit looser since I've been putting a few more miles on it. Actually I am probably going to have to take a link or two out this weekend. Is there a downside to not using a chain tensioner? If so I would like to know before i take any more links off my chain. My friend is using the chain tensioner on his bike and we have noticed that mine running without one seems a bit smoother.
My tenshioner didnt break, but what happened was my chain had to much slack, so i removed to many links and I didnt want to use another chain so I removed the tensioner and off i went, I will see in time is I need to use one or not, but so far so good with out the use of a chain tensioner. Plus with out it , I got rid of some xtra noise they make.
For when it is to rainy and cold outside to play with my bike .
I go here
  #52 (permalink)
Old 04-11-2009, 08:27 PM
Prasinos's Avatar
If you had enough slack in your chain to remove 4 links, you had way too long a chain. the only reason i use the chain tensioner instead of just keeping a taught chain is because my chain hits the bike frame near the wheel otherwise.
  #53 (permalink)
Old 04-11-2009, 08:48 PM
commander's Avatar
Yea Pras it was too long, and when I shortened it , it was to short. But later that day I went and cut my tenshioner down some and welded it to my frame, so now I will never have to worry about it hitting anything or making xtra noise. Problem solved
I go here
  #54 (permalink)
Old 04-14-2009, 03:07 AM
DEATH4OF4's Avatar
I Bought That Roller And Spent Half Of Saturday Trying To Hook It Up... No Luck. I Was Pretty Frustrated Cause I Wanted To Ride And I Wasted Half My Day. I Ended Up Putting A Shim Behind The Motor. I Used A 1/8 In Piece Of Flat Stock. So Far It Worked Great After About 80 Miles. Anyone Want To Buy A Roller?
Than Again, I May Need It On Another Build...
  #55 (permalink)
Old 05-02-2009, 12:59 AM
Prof Fate's Avatar
Add me to the long list of members that say dump the stock tensioner. Mine was pulled into the spokes about 20 minutes into my maiden voyage. Luckily, I was making a slow turn in a parking lot and didn’t get thrown off. But I still had a nasty bruise on my hip to show for the lousy design.
I don’t have a Tractor Supply nearby so I set about making a copy of misteright1 99’s design made from what I could find. I bought the ball bearing nylon roller from Spooky Tooth and used the same type of “T” bracket that that jasonh pictured above. I found mine at Lowe’s in the deck building section and cut it down with a hacksaw to the size I wanted. I clamped the bottom of the “T” in a vise and bent it over. With a little work using a hammer and the vise and I turned the bottom of it into a “U” shape to hold a bolt. The bracket was already snug around the bolt and I put some JB Weld on it to add a little extra holding power. For the tensioner arm I used a cheap stamped opened ended wrench with 2 washers glued on the outside of each end, again held with JB Weld. I went to 3 hardware stores looking for the right type of spring but didn’t find anything that was large enough to work. I finally hit upon the idea of using the spring off of a huge old fashioned mouse trap. Worked like a charm.
Mounting it to the frame was really simple because it required no extra fabrication. Just line it up on the 2 existing engine mounting bolts, drill 2 holes in the top of the “T”, slide on, and add lock nuts and you’re mounted. You’ll have to add/remove a handful of washers to the mounted bolt or roller to work out the best alignment.
A couple of things to keep in mind…as pressure is added to the spring, the inside diameter decreases so you’ll need to use a bolt that will move freely when spring is loaded. The tensioner arm needs to be long enough to tighten up the chain but not so long that it can rub against the back tire when under stress. My prototype is a little long but still works great.
  #56 (permalink)
Old 05-03-2009, 10:00 AM
marvin martian's Avatar
Hey Prof, I'm sure you already know by now, but your chain looks like it is getting ready to come apart. In the last pic, just behind the motor, on the bottom part of the chain, it looks like there is a pin missing. By the way, nice job on the tensioner.
  #57 (permalink)
Old 05-04-2009, 03:15 PM
Prof Fate's Avatar
Thanks Marvin. There was a break in the rain so in threw the old chain on to snap some pictures before it poured again. I have a 41 chain that i bought from Grainger.
  #58 (permalink)
Old 05-12-2009, 07:01 PM
Bikedad1's Avatar
Very nice.......now if I can only find one that will fit my bike frame
  #59 (permalink)
Old 06-05-2009, 10:35 AM
Norco John's Avatar
Hey Rynos! You have the clip on the master link backwards! Closed end faces direction of (chain) travel...
  #60 (permalink)
Old 06-05-2009, 11:07 AM
Rynos63's Avatar
Nice catch... I just noticed that... Thanks
www.RynosDubShop.com
