Stock Market Cats Alternative Energy
Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
spookytooth/schwinn cruiser engine mounting
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. I am a real new guy and recieved my kit from ST. Took it out of the box and dry ...
Old 02-20-2010, 02:44 PM
Default spookytooth/schwinn cruiser engine mounting
I am a real new guy and recieved my kit from ST. Took it out of the box and dry fitted it to the schwinn cruiser. The mounts seem to be a long way from my tubes. I need help on this . Thanks bob
Old 02-20-2010, 05:29 PM
Default Re: spookytooth/schwinn cruiser engine mounting
The rear mount should be flush up to the seat tube. Then you have to fabricate something to go on the front mount to the down tube.
The way I did it was to get a 4" x 12" x 1/4" hunk of metal from Farm & Fleet. I cut that down to about 4" x 4". Drilled a couple holes to attach it to the front mount on the engine, and a couple of other holes, just a little wider apart, so I could use a muffler clamp around the down tube.
There are a couple of places out there selling mount kits that are similar to this construction, for ten or fifteen bucks, if you don't feel like cutting and drilling - although I don't think the metal plate will be quite as thick.
Old 02-20-2010, 08:56 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Doood... If you look through all the posts here, YOU WILL FIND A WAY TO DO IT!
"Good bikes aren't cheap, & cheap bikes aren't good!"
For bicycle engine kits & bike service in Los Angeles, visit us at- www.VeniceMotorBikes.com
Old 02-21-2010, 12:31 AM
I have started looking at the different posts and there are alot of options. Nougat, I was not sure which side of the motor got the extension ,thanks. Right now I have it snugged up to the front bar, will change. bob
Old 02-21-2010, 01:22 AM
bairdco's Avatar
a guy who makes cool bikes
here's how i did mine: how i made an extended front motor mount
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
