Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Shorten rear mount ??
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. If I grind down the alluminium mount spacer evenly about 1cm will this cause any issues (this will help with ...
Old 03-19-2009, 05:41 AM
Default Shorten rear mount ??
If I grind down the alluminium mount spacer evenly about 1cm will this cause any issues (this will help with clearance issues on my large frame mtb ) 66cc 2 stroke
Old 03-19-2009, 06:07 AM
RedB66's Avatar
Default Re: Shorten rear mount ??
You should be okay. The air filter may be a little close to the seat tube. (depending on what style filter you have). You may have to install the filter after installing the carb...as opposed to installing as one unit.
You do not need a parachute to skydive.
You only need a parachute to skydive twice.
Old 04-03-2009, 04:20 PM
Earthman's Avatar
I shortened the rear mount for my engine by cutting about ½ inch off with a hacksaw then cleaning up the cut with a file and sandpaper. Cuts easily and works fine in my application (see pic). The mount may be a little weaker with respect to bending, but it isn’t subjected to that kind of force if the seat tube fits properly like my case.
shorten-rear-mount-cimg8289.jpg  shorten-rear-mount-cimg8290.jpg  shorten-rear-mount-cimg8294.jpg  shorten-rear-mount-cimg8295.jpg
Old 04-03-2009, 08:18 PM
commander's Avatar
cool Earthman, looks like a pro did that .
Old 04-03-2009, 08:42 PM
azbill's Avatar
good idea for clearance
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 04-03-2009, 09:49 PM
I thought it sould be ok just learning from your experiances
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f6/shorten-rear-mount-6805.html
Posted By For Type Date
Biking Bis - Bicycle Touring and More :: Feed Zone This thread Refback 03-19-2009 09:24 AM
