Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Schwinn Landmark Mounting
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. Iam using a Schwinn Landmark with a SICK front mount adapter. To get the 69cc front sprocket and the rear ...
Old 07-27-2009, 07:46 AM
Charged-Reacter's Avatar
Default Schwinn Landmark Mounting
69cc front sprocket and the rear wheel sprocket to line up, Do you lean the motor
back and forth until you get the correct clearance and alignment?
Old 07-29-2009, 01:20 PM
Default Re: Schwinn Landmark Mounting
After searching the mounting techniques threads and having no luck with solving
this problem, I decided to take 69cc back off the bicycle and start over. I found the
problem was caused by a casting burr inside the rear block spacer, after filing it down
and reassembly, everything lined up and the motor sits straight with just enough clearance.
I guess I will slow down and not hurry because I was anxious to get this bicycle up and
running.
