Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Pedal hits muffler
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. My pedal hits the muffler...just barely. I've read some post on bending the exhaust. I don't have ...
Old 07-10-2009, 02:18 PM
Default Pedal hits muffler
My pedal hits the muffler...just barely. I've read some post on bending the exhaust. I don't have heat or a vice...drat!! I am going to try sanding the gasket on a taper. Hows that sound?
Old 07-10-2009, 02:24 PM
2door's Avatar
Default Re: Pedal hits muffler
Not good. You'll probably end up with an exhaust leak, and that's not good either. If you don't have access to a vice you might try bolting the muffler flange to a heavy, immovable object and try bending it that way. Heat is not necessary. The pipe is pretty tough but it will bend if enough force is applied. Go slow and do just a little at a time. The best way is to use a solidly mounted bench vise. Maybe a neighbor or friend has one you could borrow? Good luck.
Over Youth and Skill
Old 07-10-2009, 02:26 PM
Retmachinist's Avatar
If it is just barely hitting, you may be able to give the mounting holes about another 1/32" clearance. Then you can turn the muffler a little bit, might be enough.
John
Old 07-10-2009, 02:29 PM
2door's Avatar
John
John,
Is that what they call, "Wollerin' out the holes" ?
Old 07-10-2009, 02:35 PM
"Wollerin' out the holes". I like that Think I'll try it.
Old 07-10-2009, 02:39 PM
Ilikeabikea's Avatar
I know a few guys that have bent the crank arm out just a little bit too. Just take the pedal off and put a long peice of pipe over the crank arm a give an ever so gentle tweak........
http://www.galtx.org/
http://bdconner.com
Old 07-10-2009, 02:45 PM
Originally Posted by 2door View Post
John,
Tom, I would call it a sloppy fit. I think in the military they used to refer to it as a "Tijuana Fit"
John
Old 07-10-2009, 02:49 PM
I like the way you said that "Ever so gentle" Funny, I say that all the time. It's also like saying "Splitting a Frog Hair" When you are working with some close tollerances.
John
  #9 (permalink)
Old 07-10-2009, 03:19 PM
While I have all of you peoples attention let me ask one more question.
My chain tensioner turns freely with my fingers. But the chain does not cause the tensioner wheel to turn. I assume that is because of the tensioner wheel being a hard, glossy smooth surface and the chain likewise. Thus, eventially the tensioner wheel will wear flat and then NEVER turn.
Is this a problem?
  #10 (permalink)
Old 07-10-2009, 03:29 PM
2door's Avatar
Sofa,
You want to check, then double check your chain and tensioner wheel alignment. It should be near perfect, or as John would say, "Closer than a frog's hair". Most of the kit supplied tensioner wheel brackets require a slight twist, (there's another need for a vice) to get it to align with the chain path. The bike's chainstay, the part of the frame it mounts to usually is not exactly parallel to the chain so 'tweaking' the bracket becomes essential. Do you like how we toss around those highly technical machinest terms here?
