| | | Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack | OVERSIZED TUBING solved Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. I Guy we ride with put the bottom tube in a vise and made it oval. We plan on a ...  | |
01-31-2008, 02:51 PM
|  | Santa Cruz Scooter Works | | Join Date: Jan 2008 Location: Nor*Cal
| | Re: OVERSIZED TUBING solved I Guy we ride with put the bottom tube in a vise and made it oval. We plan on a ride this weekend before the bowl.
Hey Gary, Register already and post pics! |
02-01-2008, 05:43 AM
|  | Moderator | | Join Date: Dec 2007 Location: Gainesville, FL
| | Re: OVERSIZED TUBING solved I used U-Bolts on my install and they work well. I also used automotive fuel line, which comes in various diamiters, to kind of shroud the bolt
__________________  You do not need a parachute to skydive.
You only need a parachute to skydive twice.
02-01-2008, 11:51 AM
|  | Moderator | | Join Date: Jan 2008 Location: Shelby MI
| | Re: OVERSIZED TUBING solved Thats a really nice looking engine mount Red. I hadn't thought about fuel line or covering the clamp in some way, I just ran a couple of layers of tape around the frame to protect it...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
02-01-2008, 01:44 PM
|  | minor bike philosopher | | Join Date: Jan 2008 Location: north carolina
| | Re: OVERSIZED TUBING solved they make a heater hose in up to at least 1" diameter I think. I used it to wrap my undersized tube. Hard to believe there is actually a tube too small for this toy. |
07-11-2008, 02:09 PM
| | Re: OVERSIZED TUBING solved |
07-26-2008, 12:47 AM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2008
| | Re: OVERSIZED TUBING solved Yea But that Clamp is $2.00 and the plate is $3.00 so you have $10.00 left over for Beer......LOL |
07-26-2008, 12:31 PM
| | Re: OVERSIZED TUBING solved Unless you have a boatload of 1/8" aluminum plate laying around then the whole thing cost you some time and a clamp @ $2.59.
And Mr. Joe said I was nuts for buying that at an auction. I've even made transmission parts for a motorcycle with some of it. Paid a dollar for a milk crate full.
07-26-2008, 06:54 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: OVERSIZED TUBING solved That's a good deal on a boatload of aluminum.
Where would I find a small piece of aluminum plate like that? |
07-26-2008, 08:00 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: Mesa, AZ
| | Re: OVERSIZED TUBING solved Be careful using straight U bolts on an aluminum frame... they will eventually tear through the frame with the vibration.
I have a design here that will distribute the loading over a larger surface area, preventing metal fatigue in these newer (thinner and lightweight) aluminum frames:
I'll post some photos of the finished product in a few minutes. Just finished them about 30 minutes ago. |
07-26-2008, 09:08 PM
| | Re: OVERSIZED TUBING solved Quote:
Originally Posted by jasonh That's a good deal on a boatload of aluminum.
Where would I find a small piece of aluminum plate like that? | You can call the aluminum supply houses in your area and ask for cut off or drops, tell them you just want a couple pieces of scrap.
I may get ambitious and weigh up a piece and see what it cost to ship and sell pieces in the swap shop (cheap).
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:30 PM. | | | Sponsors
