Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
OVERSIZED TUBING solved
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. Here is a photo of the mounts that I sketched.. Easy to make and will allow m ounting these engines ...
  #21 (permalink)
Old 07-26-2008, 10:18 PM
datz510's Avatar
Default Re: OVERSIZED TUBING solved
Here is a photo of the mounts that I sketched.. Easy to make and will allow m ounting these engines to oversized aluminum frame tubes:
  #22 (permalink)
Old 07-28-2008, 11:53 AM
Ghost0's Avatar
datz510,
So are you going to weld the one half to the rear motor mount or are you going to leave it as a separate part? Either way will work well just trying to figure out which way you are going to go. I can see this being an upgrade kit for the aluminum framers out there.
www.sickbikeparts.com
  #23 (permalink)
Old 07-28-2008, 09:02 PM
datz510's Avatar
I had to weld it to the rear engine plate due to tire clearance issues on my particular install, but whoever is doing the installation could easily slot the U bolt mounting holes to allow these to simply bolt on to the back plate, especially if the back plate is made a little wider in the affected areas.
  #24 (permalink)
Old 07-28-2008, 09:29 PM
ebmvegan's Avatar
Originally Posted by wayde View Post
here's how i took of this issue
What if a piece of rubber was placed between the modded plate and a second steel plate for both the base and top connections to the bike frame. Would it limit the amount of vibration caused by the motor? Or would be so negligible that it would be a waste of time?
There is no moment like the now moment.
  #25 (permalink)
Old 07-28-2008, 10:15 PM
RONNY_ODELL's Avatar
this will be my next mount on my Moon Dog ....
oversized-tubing-solved-motor-mount.jpg  oversized-tubing-solved-motor-mount-1.jpg  oversized-tubing-solved-motor-mount-2.jpg
ride on yall
  #26 (permalink)
Old 07-29-2008, 12:02 AM
datz510's Avatar
Man.. Those are some nice mounts!!! They look a lot nicer than mine!
  #27 (permalink)
Old 07-29-2008, 07:57 PM
Being A Cnc Machinest Comes In Handy Some Time,,, I Didnt Make These ... I Found The Pics Some Where Else,, But I Plan On Making Mine Jus Like Them .....i Though They Were Very Kool ..
ride on yall
  #28 (permalink)
Old 10-07-2008, 06:05 PM
Biker Mike's Avatar
MAN!! you could sell these mounts like crazy!! Nice work!
  #29 (permalink)
Old 10-09-2008, 12:25 PM
Saddletramp1200's Avatar
Oh Man! I have a big Dax on a Schwinn Point Beach and it keeps breaking the mounts and the motor wants to lean out the left side of the frame. I'm loosing it trying to find a way to mount the motor better. I have a bench grinder and the time to make those. Are there some for sale anywhere? I can't risk breaking the brand new motor or bike.
No matter where you go, or what you do, there Ya' are!
  #30 (permalink)
Old 10-10-2008, 10:52 PM
My china engine I'm pretty sure the piston bushing went for it was making a racket and busted my front mount it was vibrating so hard man those bolts were $2.50 a piece.
When I get around to it I'll take it apart. But I'm going with mounting the front mount the way it was meant to mount and extend out the back mount by getting longer studs and putting a few washers between the inside clamp and where it normally sits by the engine.
I thing the clamps are meant to go around the frame for strength. Just getting a plate I think puts too much stress on them M6 bolts/studs.
Advertisers
