| | | Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack | NEED HELP- mounting a 2 stroke engine on Jeep Mountain Bike Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. I've got this Jeep Commanche TS Mountain/Suspension bike from Toyz R Us(pimp, right? :P),
and i need ...  | |
06-07-2009, 09:23 PM
| | Motorized Bicycle Newbie | | Join Date: Jun 2009 Location: Cape Girardeau
| | NEED HELP- mounting a 2 stroke engine on Jeep Mountain Bike I've got this Jeep Commanche TS Mountain/Suspension bike from Toyz R Us(pimp, right? :P),
and i need help mounting a 2 stroke engine on it. I was wondering if there was any way to mount the engine in the front because it's definatly not a V shaped frame. If there is ABSOULTLY no way you can mount it in the front, then how can i mount it in the back?
-any help appreciated, thx!  |
06-07-2009, 09:33 PM
| | Re: NEED HELP- mounting a 2 stroke engine on Jeep Mountain Bike Sorry, but that bike will not lend itself well to a 2 stroke, in-frame installation. It is not impossible but the work involved will require some serious fabrication and alterations to the basic bike. If I were you and was intent on using that bike I'd explore a rack mount engine. Rack mount means the engine is mounted over the rear wheel. Check this vendor for ideas and pricing. bicycle engine kit, bike engine, bicycle engine, bicycle motor Hope this helps.
Over Youth and Skill |
06-07-2009, 11:03 PM
| | Motorized Bicycle Elite Member | | Join Date: May 2009 Location: usa
| | Re: NEED HELP- mounting a 2 stroke engine on Jeep Mountain Bike could simply use a chopper frame mount ( like what the Schwinn OCC choppers use ). build a rack that it would attach to, and run the kit that way.. would be kinda screwey but that's the only way I can see a china 2 stroke working...
actully at the cheapness of the parts and availability for the China engines, I can see that mount being useful to put the china engines in many things.. Go Karts, minibikes, ect... |
06-07-2009, 11:08 PM
| | Re: NEED HELP- mounting a 2 stroke engine on Jeep Mountain Bike Here is one option if you can do a little fabricating. |
06-08-2009, 06:25 PM
|  | Motorized Bicycle Elite Member | | Join Date: Sep 2008 Location: AZ now, TX in 2010
| | Re: NEED HELP- mounting a 2 stroke engine on Jeep Mountain Bike I agree with Fair. Put it on the back wheel. You can find some way to
mount a rack to fit your rear triangle and use a rack mount motor.
"Don't believe everything you read on the internet. That's how World War I got started" - PS3 commercial |
06-08-2009, 06:44 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: PENSACOLA, FL
| | Re: NEED HELP- mounting a 2 stroke engine on Jeep Mountain Bike One Thing To Remember, The Gas Tank Outlet Has To Be Higher That The Top Of The Carb, Gravity Feed System. Nice Bike! Ron ...............
PUMP YOUR BRAKES
NEVER BEAT ON IT, GET A BIGGER HAMMER |
06-08-2009, 10:00 PM
| | Re: NEED HELP- mounting a 2 stroke engine on Jeep Mountain Bike Quote:
Originally Posted by NEAT TIMES One Thing To Remember, The Gas Tank Outlet Has To Be Higher That The Top Of The Carb, Gravity Feed System. Nice Bike! Ron ...............  | doesn't have to be.. it can be level with it.. just would need a primer bulb to create a siphon. |
06-09-2009, 12:38 AM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: upstate NY
| | Re: NEED HELP- mounting a 2 stroke engine on Jeep Mountain Bike i like that rear mount idea.
that reminds me: my gas tank is mounted on the rear rack and i have to prime like 3-4 times before starting my bike,my tank is almost level with carb or slighty above it,so i think i will try and raise the tank another inch or two and see if it helps. |
06-09-2009, 10:28 AM
| | Re: NEED HELP- mounting a 2 stroke engine on Jeep Mountain Bike Me Dumbo, I Was Not Aware You Could Siphon Up Hill. Never To Old To Learn . Good Luck With Your Build. Ron . . . .
PUMP YOUR BRAKES
06-09-2009, 01:30 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: CT, U.S.
| | Re: NEED HELP- mounting a 2 stroke engine on Jeep Mountain Bike Just an off the wall thought, but your bike looks like it would fit a morini motor under the down tube. That would be awesome.
Big bucks and some fabing though.
__________________ Quote:
Originally Posted by NEAT TIMES looking In The Sky, May See Dan Flying By!! Ha Ha Ron | I want 2 ride my bicycle | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:50 PM. | | | Sponsors
