Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Mounting Suggestions
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. Is there a way to mount these engines to a large frame WITHOUT drilling a hole or using a already ...
Old 03-22-2009, 10:21 PM
Mopedamauter79's Avatar
Default Mounting Suggestions
Is there a way to mount these engines to a large frame WITHOUT drilling a hole or using a already drilled hole to secure the engine. The engines simply do not come with brackets that are wide enough to account for the average frame. I have found unless it's a small tubing you have to use the large frame adaptors or grind down the frame so the bolts clear the frame.
Because I have a larger frame I had to have a hole drilled into the middle and have a large frame adaptor attached to original studs and a long bolt going through that into the hole.
I have been checking the bolts and nuts and everything seemed fine it was literally just one day it snapped right where the bolt goes into the engine.
Old 03-22-2009, 10:26 PM
Spunout's Avatar
MB Builder Extraordinaire
Default Re: Mounting Suggestions
oh yes. i take some longer metric bolts and cut the heads off. screw them into the motor and spread them apart. drop motor onto frame, bend them back in and put on the bracket. easy. really easy.
the bolts shown are actually rear mounting bolts, but you get the idea.
New, fully assembled motored bikes here: http://happytimecycles.wordpress.com/
401-952-7064
Originally Posted by Dan View Post
sn0rk.
Originally Posted by Bikeguy Joe View Post
You are one sick man spun, I like that quality in a person.
A 20-year smoker, I quit smoking with the help of this--->http://www.premiumecigarette.com/415.html a smokeless, non-tobacco electronic cigarette.
Old 03-22-2009, 10:37 PM
Hmm Interesting Idea.. Does that weaken the bolts at all ?
Old 03-22-2009, 10:41 PM
Spunout's Avatar
i dont think so. youre not bending the $hit out of them, or anything. ive been doing it that way for 5 years, and have had no trouble.
401-952-7064
sn0rk.
Old 03-22-2009, 11:02 PM
It's worth a shot. I'll head over to the hardware store and look into some stuff to get that bolt out. The bolts you use what strength are they ? Just standard ones you get @ the local hardware store ?
Old 03-22-2009, 11:08 PM
Spunout's Avatar
i dont know the strength off hand. anything good is better than stock
401-952-7064
sn0rk.
Old 03-22-2009, 11:29 PM
robin's Avatar
I just mounted my 80cc and all i did was file the alluminum mount to a wider mouth --as well as the longer bolts it works great !!
Old 03-23-2009, 01:12 AM
The bolts themselves don't even clear the bike frame.
  #9 (permalink)
Old 03-23-2009, 08:56 AM
Spunout's Avatar
in length? get longer ones.
in width? spread them apart a bit.
401-952-7064
sn0rk.
  #10 (permalink)
Old 03-23-2009, 09:22 AM
Bikeguy Joe's Avatar
OVERSIZED TUBING solved
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f6/mounting-suggestions-6895.html
Posted By For Type Date
Biking Bis - Bicycle Touring and More :: Feed Zone This thread Refback 03-23-2009 03:38 AM
